RCU Forums - View Single Post - Control issue
Old 07-19-2009 | 12:39 PM
TruBlu02's Avatar
TruBlu02
Default RE: Control issue
ORIGINAL: ro347
If using aileron and elevator to turn....add a smidge of rudder to hold the nose up through the turn.
The rudder will be used to cancel out adverse yaw so you will need it to lower the nose. Mostly in a right turn. The nose will want to move in the opposite direction of the tunr due the drag of the raised wing.
