RCU Forums - View Single Post - Flair Puppeteer Build
Old 07-20-2009 | 05:42 AM
cymaz's Avatar
cymaz
Default RE: Flair Puppeteer Build
This morning carefull cut to length all the cross members sanded to fit and cyno glued them in. For reference the angle of the cross member cut is 5 degrees. Double checking that the fus sides are perpendicular to the lower cross members and therefore the "oil rig" as the plan refers it to is parallel.
I will now wait until everything is thoroughly set, probably 24 hrs.
ID:	1240457   Click image for larger version
ID:	1240458   Click image for larger version
ID:	1240459   Click image for larger version
