RCU Forums - View Single Post - Tail Dragger Question
Old 07-20-2009 | 07:11 AM
WestCoastFlyer
Default RE: Tail Dragger Question
ORIGINAL: Korps
I never hold full up elevator on take off roll. Yes I taxi with elevator up. Then I set up and let the plane roll. Usually the elevator is at neutral, I do however tend to think what the ground/runway is like. For some or other reason if I know we are using the grassfield runway, I know it's not smooth as the gravel and the grass makes it a bit more ''sticky'' for the wheels. In this instance I tend to give a little bit of up elevator - it seems as if the plane then gives a much smoother take off roll and gets in the air faster. On the gravel runway it isn't neccesarry.
So it depends on surface for me. Stupid probably, but it hasn't had a bad effect as if yet.
You've got it right, the heavier the grass the more up elevator you need. It's a feel thing. Total full up taxi, full up takeoff roll ease off and go to rudder - which is why us Mode 1 guys have it so easy! lol. All that happens on the left stick, very convenient. Too bad Mode 2 guys lol.
