RE: SPA Aircraft Engines
The SF is a long stroke engine. The piston/liner are the same dimensions as the Hanno Special. The con rods are the same part number. I modded the exhaust ports in a ringed SF liner to approximate the exh. ports on an ABN Hanno II liner and the SF turns (with a tuned pipe on both) at very nearly the same rpm with a 13~9 APC.
Terry in LP
