RCU Forums - View Single Post - It actually flies!
Old 07-20-2009 | 03:50 PM
tony0707
Default RE: It actually flies!
HI learning to fly(NO DUMP THUMPS-only mechanical issuses causing your crashes-and only a few of those) and building a plane that flys on rails -is the beggining of mastering this great hobbywhen you can maden your own aircraft-trim it out and -are able to work out the bugs that most planes have the first 10-15 flightsyou are now an acomplished RC pilot and airplane builder it takes time you are at the begginning of one great rewarding hobbywelcome to this great experienceyou will get a lot of good help if you askwhen you get it rightjust give back the great education you have received from othersthats is alot of what this hobby is about-only ask the best you see do what they do for help and advice-with determination you will sucseedbest of luck-HAPPY LANDINGS-REGARDS TONY
