RE: hz super cub problems
Ya, I'm good enough that I can fly with ACT off. I looked it up and you guys have named everything that other people said were wrong. The only thing that you didn't mention was that the crystal in the plane comes loose sometimes and the way to fix that is to take electrical tape and tape it down. I did notice that the crystal was loose. I've already taped it and did a range test. It seems to work. I'll have to fly it to get the real answer. It makes sense because on my last flight I noticed that it only sputters in the first 2 minutes of my flight so I guess it stops when the crystal settles back into place and I guess when the plane takes off it knocks the crytsal around.
