RE: balancing a full flying stab
So how would you guys recommend balancing the stab ? shall i let it pivot freely on the shaft by using a bearing of some sort, and then add lead weight in the root of the stab in the leading or trailing edge until the CG is right on the pivot ? or is there some other way ?
Shall the CG be right on the pivot or slightly in front of it towards the leading edge ?
