RE: AMT Pegasus and ASU help
Alright, I just pulled the ECU and battery out of the jet. The ECU says Version 4.33 and is dated 97.08.01 (assuming that's the date, maybe not, the letters before that are HWVER)
Surprisingly, the ECU battery that I pulled out was a 7.2V 700mah pack? It fit in the CAI battery box perfectly, and it has the AMT ECU leads on it (the thick black ones) but the last Pegasus I had used an 11.1V battery pack, did the older version's use a 7.2V then (I assume they must have as this jet has flown more than once by the previous owner). I need to charge the battery pack, I'm sure it's low, that may be why the ECU won't beep at me with the 3 position switch or throttle, it beeps when it turns on, after about 30 seconds it just starts beeping.
Anyway, I have to head off to work now anyway, but I'll charge up the battery while I'm there and try again tonight.
Does it sound like I'm missing anything else?
Thanks again
Jeremy
