RCU Forums - View Single Post - Programmable head
Old 07-21-2009 | 12:23 PM
PilotLight's Avatar
PilotLight
Default RE: Programmable head
I would still like an explanation of what each setting, or combination of settings, or adjustment does. The flybar links that tilt the flybar and control the flybar paddles does not change in length or leverage, but the leverage from the flybar to the blade grip does. So does the leverage from the swashplate's linkage on the blade grip. I'm just not sure how they all interact and which setting is twitchier and which is calmer.
I imagine if they are closer in, it gets quicker. What happens with one on the outer hole, and the other on the inner hole? If the outer holes are calmer say a one on a scale of 1 -5 with 5 the quickest, and the inner holes are a 5, then what combination is a 2 or 3?
I took the weights off the flybar paddles and it was soo twitchy I couldn't control it. The plane of the blade disc was tilting all over the place before it left the ground, so I never lifted off.
Ok, I think I asked the same question enough times.
