Help!!!! Very strange behavior.
Ryan,
Since you are 200 miles from home and it is still exhibiting the same problems, we can safely rule out any outside interference in your area.
I agree with Ross that it sounds like a receiver crystal problem.
If changing out the crystals from new ones does not correct your problems, then I would send in receivers and crystals together to the service center so that they can be checked.
Thanks, and good luck, Krysta
