RCU Forums - View Single Post - Leaking saito, normal?
Old 07-21-2009 | 11:58 PM
MetallicaJunkie's Avatar
MetallicaJunkie
Default RE: Leaking saito, normal?
ORIGINAL: Gray Beard
Did you bother to put a piece of fuel line on the pressure relief nipple?? If not then BIG GUNKIE!!! You have to run the line out of the cowl so it exits out the bottom.
I think my saito 120 may be leaking too/ It runs sweet, no complaints other than i notice some oil leaking out the botom of the cowl creating a bit if a mess,even though i have the crank case vent fuel line routed to exit at the bottom of my landing gear
