ORIGINAL: bmclaughlin
thanks for the input. Regarding the hub, am I correct in assuming it is keyed so that the new hub will align to be "timed" correctly? and of course as luck would have it the only socket I can't locate is my 11 mm deep.
You arecorrect, they are keyed. I hope you won't be to disappointed when you find your 11mm deep socket and it will only reach 1/2 way to the hex.
