RE: DL 100 - New Twin on the Block!!
Hey Jody, would bmclaughlin be correct that the magnet will be in the same spot on the hub in regards to the key way? Time will be the same as with the old hub? A pull and replace and that's it?
I do know that the hubs prop bolts are in a different spot and the prop will be clocked different.
