RE: DL 100 - New Twin on the Block!!
Yes, the magnet is in the same position relative to the keyway BUT, I always check the timing after I replace a hub, sensor, or module, it takes about 1/10 the timeto do as it takes to R&R most cowls. It's common to be off1 or 2 degrees +/- with one of those components being replaced butnot far enough to cause a problem 99.99% of the time.
