RE: What the diff?
my vx has a rotary carb, but you can add the slide carb (not side carb.) to it.
the rotarty carb is just that. the throttle "barrel" in the throat of the carb rotates as you give it throttle.
with a slide carb, the throttle "barrel" slides in and out rather than rotating.
