RCU Forums - View Single Post - Help! Landing gear weak!
Old 07-23-2009 | 08:58 PM
Lnewqban's Avatar
Lnewqban
Default RE: Help! Landing gear weak!
From the manufacturer:
"Composite landing gear evenly distributes landing stresses, with a flowing shape that enhances the plane's overall appearance."
The engine is heavier than the recommended 32-43 cc; hence the gear may be flexing beyond the spring limit, getting deformed.
I suggest beefing the higher portion of each half with similar flat material on the inferior surface.
Glue will be better, but rivets could work.
A new gear needs to be thicker.
