RCU Forums - View Single Post - Simple Things to Add Speed - Your Tips
Old 07-23-2009 | 10:30 PM
MJD's Avatar
MJD
Default RE: Simple Things to Add Speed - Your Tips
ORIGINAL: Textanker
Me and my buddies have caught the speed bug. We are currently trying to wring out every ounce of zing from our planes. What are some things you have discovered that are simple/cheap upgrades to give you that extra zip?
30"-34" span 1" thick wings with 2+hp engines - this is a good start!
But as to your own planes - like with weight reduction, take care of the little things.
- Fillets at wing/stab/fin to fuselage junctions
- Cowl the engine - huge amount of dirty junk up there.
- Light weight - within reason structurally of course - drag is a byproduct of lift
- Tight clean control surface junctions, match surface thicknesses and profiles
- Sharper TE's do indeed reduce drag, esp when the sharp(er) edge is a smooth extension of the airfoil and not an afterthought
- Ensure wing-stab relationship is at or darn near at 0-0, trimming out climb robs speed.
- Well balanced props, aluminum spinners not plastic, solid engine mounting all result in more rpm/less wasted power
- Concealed or faired-in control linkages
- Forward CG's require more trim = more total lift than needed = more drag
and much more..
MJD
