Question re Hobbico Air Alert
I have these on my planes....we have a lot of trees around our field! When I first started using them, I emailed Hobbico's tech support and asked them why throttle. The answer I got was you can plug it into any channel. I usually have mine on the airlerons.. I can't fly for very long without some sort of wing waggle, also, I found that with a longer than normal taxi/wait to take off with it plugged into the throttle, I'd have to blip the throttle to stop the beeping indicating no stick movement... something you might not want to do. With it plugged into the airlerons, all you have to do is give them a little wiggle.
