RCU Forums - View Single Post - What the heck is the white dot??
Old 07-24-2009 | 09:59 AM
ira d
Default RE: What the heck is the white dot??
ORIGINAL: BaldEagel
As far as I know the only people who had problems with overheating where using the Rx in extreme conditions (Middle East) as far as the low voltage issue I have an FS version in an Elan with all digital servos and it works without problems, none of my airframes use Y leads they can be the source of problems, I also do not use 4 cell AA size 4.8volt batteries to supply my Rx and servo's.
Mike
Its not just the Middle East but here in the states also people had heat problems, However the bottom line is the non dotted receivers can not be used the
same way as the dotted one's and others that are currently on the market because more precautions have to be taken in high heat environments and I
would say this is more true for the 608 6014 non dotted receivers.
