RCU Forums - View Single Post - DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here
Old 07-24-2009 | 02:58 PM
kygah
Default RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here
ORDER Number:yhst-17210252890263-87763
<div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">I received this order today and have some serious issues with the airplane.</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">http://www.nitroplanes.com/f4uco4elrare.html</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">#1 &ndash; Servo will not fit inwing. Hole is not cut out properly to receive the servo that was sent. Also, correct screws not sent to secure servo.</span></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">#2 &ndash; Servo opening in wing, the plywood support is broken.</span></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">#3 &ndash; Right aileron is detached from wing. Hinges are not glued in place, and control is very sloppy.</span></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">#4 &ndash; Left aileron is VERY stiff, and has limited control movement. This may be normal and acceptable. It is securely attached to wing.</span></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">#5 &ndash; Vertical stabilizer is out of alignment with the aircraft.Tilts to one side, and is not square with aircraft.</span></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">#6 &ndash; Rudder is not in alignment with the vertical stabilizer. I thought the vert stab might be tiltedto counteract torque of engine (similar to down and out of engine), but the rudder is out of alignment nonetheless.</span></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">#7 &ndash; There is no way to secure the receiver and ESC. I can take care of this, but the instructions show it being included.</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">I would like to return the entire airplane. I am very disappointed with the entire aircraft.
Ican post pictures if necessary. Please advise.</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">Respectfully,</span></div><div style="margin: 0in 0in 0pt"><span style="font-size: 10pt">
Gregg</span></div>
