ORIGINAL: rowdog_14
it is a 3500 mah 4.8 volt battery. I really do not think it is a battery issue. I think I just might have a bad servo because it does sound like it struggles to pull up the gear compared to my other 791 servo.
It sounds like you solved the problem then!.....
I had a futaba servo on a rudder that looked like it worked just great. It was rated at over 130oz, but had less strength than a 8$ dollar 45oz.....servo...
Replaced the servo, no more issues.....
