RE: Two bolts on main shaft.... special steel or not?
I'm not sure what I'm trying to achieve with the trim. On the coaxial I had it was easy. I just adjusted it until it would stay in a hover, but with the b400 on the sim it seems like the trim only works at a very narrow window. If I hover 4 feet off the ground I can make it stay still. If Iraise the elevation a little then I start to drift again. Is that normal? What should Ibe trying to achieve or how do I dial the trim in the right way? Thanks again for you response. I appreciate all the help you and this forum has provided.
-Robert
