RE: AquaCraft Alligator RTR
Donahue 85, yes you need to patch any holes. The inside of the hull is full of a foam that WILL absorb water. It does not appear to be a closed cell foam, which is what should have been used. You should also run your engine a little rich to help keep the engine from overheating. Dennis
