RE: the hyper st PRO thread!
Ive heard ogf people doing all sorts of mods to their braking systems and to tell you the truth all I found that was the culprit in the braking was the power of the TX battery not giving the brake pads "full bite" and the positioning of the brake linkage on the servo horn...I nmoved the linkage in one hole on the servo horn and added an 11.1v volt radio battery and lemme tell you...steers like crazy and the braking is like nothing ive ever seen...2800MAH lipo from intellect with the futaba connector. problem solved.
