RE: Heres a question for you pros
If the old stripes are self adhesive (stickers) you can desolve them with CA remover. A little rubbing alcohol on a paper towell, then some windex should get most everything off. Once everything is off, use a heat gun or Iron to tighten things up before putting on new stripes. If it has wrinkles before, you won't make it any smoother by putting something over the top.
good luck,
Mike
