well, I am not going to worry abotu cutting them, I did a woopsy, that is what happens when you try to rush stuff and are a little tired
I just taped the threads in the hardwood, and I put a little thin ca in the threads to make sure they were a little stiffer, then, I gave it a few minutes for the ca to dry, then I was not thinking and decided to test them out one more time. A few hours later I went to go take the wing off, well guess what the nylon bolt got gled to the wood. I had to vice grip the bolt out in a few secitons then, I had to drill out the remainder and retap. It is done now, but darn that took some extra time.
Thanks guys
Jon
