RE: E-poxy use for firewall
An easy way to add strength to a firewall in a situation such as yours is to pin the firewall. Drill holes through the side of your fuselage into the firewall. Then use a small amount of epoxy and drive the dowel rod into the drilled hole. Cut the dowel off flush with the fuselage side.
Ken
