RE: Sig Hog Bipe, and and e-Flite 60
Hey Lyndon,
Good luck with the re-maiden. Your system seems to be fine. The 52Amps looks fine. It won't be pulling 52A at anything but full throttle regardless of what GG thinks. Not sure where her theory says that it is pulled at all throttle positions.
Still a little puzzled about that crash. Were you running an Rx battery then, or did you have the BEC in use at that time? I wonder if it was overheated, how many servos do you have in the plane? Did you see where your LVC is set to?
Have fun. We'll have to get together again sometime to fly, I just finished up my Giles202 that I converted to E-power. Should be a fun little flyer.
Curtis
