Servo Repair.
I just got a Precision Aerobatics addiction, upon inspecting it for flight i noticed that one of the screws for the elevator servo had been pulled out. The wood below it doesn't look damaged. I have heard that i should use wood glue when re-screwing servo screws. My question is should i fill the hole with glue and let it cure then rescrew it, or should i put in the glue and go ahead and rescrew it to let everything harden together? Thanks for your input and any other techniques will be greatly appreciated.
