RE: Hatori Header for Skymaster 60 needed...
Actually the Skymaster header is sorta odd...You are correct..the pipe is enclosed in the top of the fuse like the Magic (and Desire)...The offset is fairly large so I don't think a normal "fuse top" style header would work...I've attached a photo I found on Singapore Hobbies website...
Yes Sir I did get the Skymaster off "the bay"...I'm very excited!!
Your right I could get the dimensions off the print (duhhh..)...That's probably what I'll have to do and then check with Mr Muller to see if he can fab one for me...That may be the best plan....
Thanks...
Chuck
