RCU Forums - View Single Post - Need help with thunder tigre 4 stroke
Old 07-28-2009 | 06:47 AM
nixer
Default RE: Need help with thunder tigre 4 stroke
Hi GoIrish,
I had similar problems with a four stroke once, they can really test you! I found that you REALLY need to lean out your lsn to a point where you barely think it will run, and work back to a reliable tick over. Leave your hsn wide open during tis stage.
Now move on to your hsn, starting at the factory reccomendations, or just try 3 turns out, then gradually lean until you get a good rpm.
Hope this helps, though you'e probably tried all this already!
Nixer.
Up the Déise!
