RCU Forums - View Single Post - Dissapointed in OS service
Old 07-28-2009 | 02:17 PM
tsperry88
Default RE: Dissapointed in OS service
To Hobby Services:
You might be interested in what others have to say. If you don’t take the time to read the discussions, below is a summary. This is not to say I did not use after run oil. I did. Very liberally. Every time.
From Cool Power FAQ: "Should I use after-run oil? No! Most of our flyers don't use any after-run. Petroleum based "after-run" oils do not mix with methanol-based fuels. So, we definitely don’t recommend any petroleum based lubes. Our built-in after-run oil is one of the most universally recognized features of our fuels."
” I'd ask Chris S. , since he is into FAQ's, if he has happened to read Cool Power's FAQ's and how you are supposed to decided who's advice to follow."
"While the manual for the 46 AX does say to use After Run Oil, it does not specify any amount. Cool Power does contain After Run Oil in its mixture and Morgan Fuels recommend to NOT use After Run Oils as they do not mix with their fuel."
"I wonder if OS or Hobby Services wants to go on record that Cool Power should not be used in OS motors. Or to ignore the fuel manufacturers recommendations? Perhaps Chris. S would like to comment on this."
