RCU Forums - View Single Post - Dumb Question about Flutter
Old 07-28-2009 | 03:55 PM
Rodney
Default RE: Dumb Question about Flutter
As said above, the gap has no bearing on whether or not a surface will flutter. Everything will flutter given the proper stimulus. Those who say they cured a flutter problem by sealing the gap may have eliminated the flutter but it was not because they eliminated the gap. They also changed something else, most probably by making the surface slightly stiffer and eliminating any slop in the hinges which helps prevent the trigger that initiates the flutter.
