RE: Two bolts on main shaft.... special steel or not?
Thanks again. I tightened up my blades, and bought a new main drive gear with bearing. I noticed that it is not lubed like the one that was stock. Upon reading in the forums I learned that some don't lube them at all some use oil, which I don't think is wise, and someone else said to use red lithium grease. That looks like what was on the original. What do you guys suggest for the oneway bearing? If Iuse the grease do Ijust rub a little on the inside?
