RCU Forums - View Single Post - ZN Line Xigris Build Thread
Old 07-29-2009 | 09:59 PM
can773's Avatar
can773
Default RE: ZN Line Xigris Build Thread
Next, I took a trip back to Nedim's place to join the wing to the fuse and make the fillet so the fit was nice.
Since the wing is pretty low in the fuse its hard to get the wing to fit just perfect, so you need to build up a bit with epoxy/microballons.
Lay down some wax paper and hold it in place, mix up a good thick batch of epoxy/microballons so that it wont run. Get a small plastic baggie and cut the corner slightly, place in your epoxy mix, and then use the baggie like a icing tube that they use for cakes to place a nice bead of epoxy along the wing root where it does not match the fuse.
Place the wing on the tube against the fuse, and scrape off the excess glue, and let it setup until cured fully.
ID:	1246157   Click image for larger version
ID:	1246158   Click image for larger version
