RE: Mini T...Mini Desert .......?
note to add the desert truck also has a slightly longer wb. it can be driven alot harder and easier to control. and handle rough terrain much better.i do not own the min dt but i have a mini t, i also own a tamiya desert gater that is a little closer to the desert truck in length. both are really fun.both are brushless running 3cells. with the tamiya i can drive it ALOT harder with much more control. not saying get the desert gator. if i were you i would get the losi mini dt. either one would be fun. worst case you could buy the chassis plate, shock towers( i believe)and body for the shock towers. to make up for the mix up. i also think that they come with every thing to run( both models)not sure on that. got my mini t as a roller. hope a little more info to add helps
