RCU Forums - View Single Post - ZN Line Xigris Build Thread
Old 07-29-2009 | 10:46 PM
can773's Avatar
can773
Default RE: ZN Line Xigris Build Thread
Now its time to separate the surfaces. After separation you will need to bevel back the elevator (ignore the fact that the hardpoint is not in that picture, I got a little ahead of myself when I was bored) to allow for the throw of the rudder. I simply used 1/16" balsa. Again back it up with thicker balsa when taping to avoid distortion and sand smooth when done. You should leave a bit of room between the aileron and wing so its not too tight after covering.
The last picture is a little further along, but shows what the root cap on the elevator looks like.
ID:	1246205   Click image for larger version
ID:	1246206   Click image for larger version
ID:	1246207   Click image for larger version
