RCU Forums - View Single Post - Pull start
Thread: Pull start
Old 07-29-2009 | 10:53 PM
UrcHobby's Avatar
UrcHobby
Default RE: Pull start
Nitro Motors will run backwards if started backwards. Nitro motors are only like 2 stroke motors on how they receive fuel through crankcase and use the fuel to lube the rotating mass inside the motor, And nitro's run on principle of a diesel motor, by using the heat and compression to ignite the fuel.
