Hi Frank
Yes gear doors close once gear is extended. I'm using the UP2 valve which does not require a special servo. Single servo, set gear and door speeds via needle valves...which are part on the UP2. Check out links
Mike
http://www.dreamworksrc.com/catalog/...roducts_id=206
http://www.rcscaleproducts.com/retract_acc.htm
