RCU Forums - View Single Post - quick question on tuning
Old 07-30-2009 | 07:36 PM
rcadict
Default RE: quick question on tuning
ORIGINAL: Pathous
Your symptoms seem to point towards a lean high speed and rich low end. Try leaning the low speed needle 1 to 2 hours and richen the high speed needle 1 to 2 hours and run it. Your idle will probably be a bit high but will not drop down. Now you can lower the idle speed a bit.
i do believe you were correct; i had to lean it a total half turn on the low speed to finally get it, now it doesn't hang on the high idle or load up after 15 seconds of idle, it's a little snappier of line also, i thought it was pretty good before, i bet it's going to do better at the track as far as spooling up out of corners, thanks again
