RCU Forums - View Single Post - Rainbow models ducted fan unit
Old 07-30-2009 | 08:59 PM
mark_d
Default RE: Rainbow models ducted fan unit
Go with soft ramp up, start with the lowest advance setting and see how hot the motor, esc and batteries get (more advance= more power and heat usually), soft cutoff unless you would like the throttle to suddenly cut off when the battery reach cutoff voltage. Not sure what break is, you'll need to look at the esc documantatin to see.
