RE: O.S. Max-H 40 Help Please
If has been sitting in a box for 20 years the ring might be stuck; look in the exhaust and look at the ring while changing directions; you should see it wiggle. It is one of OSs best engines and my first big engine so I like them. I would also start the engine at a lower throttle setting and then go to WOT. It needs an idle bar plug and castor and it should run for a looong time.
