RCU Forums - View Single Post - Combat models jets
Old 03-10-2003 | 11:15 PM
  #37
Stratotanker
Default Combat models jets
A couple of suggestions. If I were to build this jet again I would do away with the spectra string and hook up air cylinders on the doors and the other would be to cap all of the aileron/rudder surfaces and pockets with balsa and use pin hinges. Also I would reinforce the area where the landing gear mounts are glued in with some carbon cloth before you glue them. Good luck!
Chris
