ORIGINAL: Jone951
im deciding between the genesis 450 v2 and the v2 blueray 450 and i dont know the pros and cons of the belted system and the the geard system. also what heli would you recommend between the 2? thanks
I'm not sure if you know this already but none of the models you listed above is a torque tube setup. the genesis and the blueray bothhave belt drives. The trex450 PRO is a torque tube setup. between the blueray and the genesis I'd get the blueray.
