RCU Forums - View Single Post - ELECTRIFLY POLY CHARGE4 HELP
Old 08-01-2009 | 10:58 PM
bobferguson's Avatar
bobferguson
Default RE: ELECTRIFLY POLY CHARGE4 HELP
When you press the start buttons the leds should turn green. After two to three minutes they should start flashing. The number of flashs is the number of cells detected. You should all ways check this. The charger beeps and the lights turn red when the charging is finished.
