RCU Forums - View Single Post - Walbro Carb and RPM's
Old 08-02-2009 | 11:28 AM
GPmax
Default RE: Walbro Carb and RPM's
ORIGINAL: The Raven
Definitely get a two needle carb, specifically one with full adjustment ranges.
For example, the Zama carbs that come on many Homelites appear to have two needles covered by a plastic limiter. Even with the adjustment limiter cut off you'll find only one needle is really adjustable.
To get a full range of RPM you need a two needle carb with approximately 11+mm of venturi. A WA167 does this at 11.11mm.
A member in my club has put a very large Walbro on his Ryobi and it runs better than any other conversion I've seen. Very reliable setup with well over a 100 recorded flights. I intend to identify the carb model for myself and, so I can share it with others here.
How and WHEREcan we review and find which Walbro carbs have what sizes and venturi's? THe Walbro site is impossible to find specs on. Ihave the option to buy a cheap WT-532 but can't find specs or venturi sizes?
