Flaperons
If you are using a computer radio, you can set your ailerons to reflex upwards slightly at low throttle, after being armed with the Landing Switch, and drop back to the normal position above half throttle. I use this setting on most of my airplanes.
Since you have separate flaps and ailerons, you also can use the Ultra Stick setup and use crow for landings.
