ORIGINAL: qwertypemdas
Ok, I found the coolest plane EVER IMO!!! The Diamond Dust!!! Clocked at over 200mph in level flight and it weighs only 2lb. [X(] It's easy as pie to build and fly because it can fly sooo slow with it's low weight. Anyone here have expirience with these kits? Amazing kit as well. Inludes averyting all carbon fiber even ball links and pushrods. It even includes some covering tape. All laser cut and it rubber bands together before you apply a drop of glue! I've seen them fly and this is just the best plane i could think of existing. I plan to hook it up with a nive 40 and a tuned pipe. Plz leave opinions and such. Idk but this seems pretty good. Oh, and the kit is ONLY $75!!! It also looks awesome!
I think any plane that can do 200MPh might require a bit more than you might be able to handle with only LT-40 time on your side. Think this one over. And remember a 2 pound plane will be bounced all over the sky in any type of wind. Perhaps you should try to find a set of plans for a "stik" and either have it cut or cut it your self. Just for kicks check out the "Giant Stik" at AMR.... I think it is like a 150CC version of what you want.
Good Luck always.
