RCU Forums - View Single Post - LT-40 porker
Thread: LT-40 porker
Old 08-02-2009 | 08:28 PM
Live Wire's Avatar
Live Wire
Default RE: LT-40 porker
Where are you checking your CG. it shows 3 1/2 to 4 1/8 from leading edge of wing. Great Job on the plane I just can't see where you put all the weight. The 82 will work and with the battery under the fuel tank next to the fire wall All you should need is 2 oz.s maybe a little more it will still fly great in the 6lbs area.
Larry K
