RE: aluminum parts vs plastic parts
When aluminum is used in place of plastic, it will break at the next weakest point. For example, if you would normaly break a plastic a arm, with aluminum, it would either break the mount or chassis, posibly both. A arms are cheap, chassis can get expencive.
I use aluminum arm mounts and plastic arms.
